Collins� COBUILD English-English Dictionary from TomTom
7 replies · 4,090 views · Started 28 April 2002
Hi, does any one try this English dictionary before? Well, I have run into a problem after installing it. An error occurred as I ran it. I have been told that the Fonts folder of 9210 must contain swabru.ttf and swarru.ttf these two files. However, the fonts of my 9210 has changed to Linda.gdr which can read the Chinese SMS, phonebook, and doc. files. Should I have to change the fonts to the original English environment?? And my friend with a 9210c also runs into the same problem...anyone can help me?
You may need to download the euro version of the character formation for your comm. There are many symbols which cannot be created by the standard euro fonts so if you translate/convert/whatever they may be able to run the prog. I don't knowif this is the prob but it worked in reverse when i needed to create Eastern symbols
Well, my problem is...I can't even run it. Whenever I run it, the screen of "Collins Cobuild English Dictionary" has blinked for a second or two and an errorous message appeared! <my 9210 is v3.18>
btw, you mean it can be solved by replacing an European font?
The only chance you have to get this application to work error-freely is if you copy the .sis file onto your device (memory card of course) and you install it directly on the phone. It worked for me when I finally tried this method.
Nah...it shows
"Application Closed
Application CoBuild
Reason code E32USER-CBase
Reason number 21"
However, if I change my Linda.gdr (font that can read Chinese) to the swabru.ttf and swarru.ttf, it can work...meanwhile, I can't read any Chinese SMS or phonebook>_<
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2002-04-29 1325, Mac wrote
Nah...it shows
"Application Closed
Application CoBuild
Reason number 21"
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Hi may i know where do you get the Linda.gdr ... because i also want to read chinese .... or could you kindly sent the file to me ....Thanks ... my email is [email protected][email protected]</a>
I've already written twice about my problem, but now I hope I can get help!
The problem nor TomTom dictionaries, neither any other programs from them works any longer on my comm. They just end with an error message as on the comm the Chinese pal here.
I have a German Communicator, but I installed many dictionaries from many manufacturers and, among them the Russian firm Slovoed.
They said I need their special utility to display Russian characters and i installed it. After that I noticed I cannot run any of the TomTom aplications.
I did all I coud, deinstalled all programs, even formatted my Comm and mmc twice and installed TomTom as my first and only application, but still it ends after the greeting screen!!
I would think my Comm is fault, but my wife has the same story on her machine, too.
Nah...it shows
"Application Closed
Application CoBuild
Reason number 21"
you can download from www.epocn.com/big5softdown.htm
