Hey guys.
Title says it all really. Upgraded to V20 (vodafone) 2 days ago and the phone's crashed about 5 times, all directly after sending text messages.
Any advice?
Thanks,
Ian
Hey guys.
Any advice?
Thanks,
Ian
Which drive are you storing them on? If its the C: drive, how much space do you have on that?
I would recommend using the E: drive for storing messages if you're not already.
To do that go to Menu->Messaging->Options->Settings->Other.
Note: Whenever you back up the phone you will need to reset this.
Regards
Neil
Omroth wrote:Hey guys.Title says it all really. Upgraded to V20 (vodafone) 2 days ago and the phone's crashed about 5 times, all directly after sending text messages.
Any advice?
Thanks,
Ian
You are the first person I have read about with this issue.
However, problems after FW upgrades are more likely to be software related than hardware.
Did you restore a Nokia 'backup' file after the FW upgrade? This is not recommended and causes all sorts of issues.
I would recommend you synchronise your contacts, calendard, pics, etc using PC/OVI Suite then perform a hard reset
The traditional method won�t work as the N97 doesn�t have the old keypad. After you�ve backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons below.
� Caps shift
� Space bar
� Delete button
� On button
Keep the first three buttons pressed down until the Nokia boot-up music plays.
Hey guys.
The error seems to have subsided yesterday... I've done the drive thing, thanks for the advice guys. Will try the other thing if it comes back.
