:-? i am thinking of changing my 9210 to the p800. can anyone let me know the following please.
can i edit / write word and excel docs as in the 9210?
can i move over my data from the applications on the 9210. calender ect?
has anyone ells moved over from the 9210? if so what do you think?
regards
Peter
I did ... It was a disaster in the contacts and the calander.
1- the contacts had to go to outlook whichis ok , then synching outlook with the P800 took all contacts but it takes only one phone number!!? why?
Dont ask me :roll:
2- My calander totaly messed up you will miss that nice color coding of events in the 9200.... I am still waiting for a nice third party App to satisfy my needs in a calander.
3- Grouping is an option from nokia that should of been adopted by SE.
4- I use to hold my personal data using Code Vualt fro 9200
now a backed up every thing but they are not reuseable on SE becuase code vualt is not compatable with OS 7 :-?
ring tones must be set for every individual contact!! Crap.
but for every thing else SE performs very good .
you need to do some work before you switch . but make sure you buy the SE before you sell the 9200 to make sure everything transfered the way you wanted it .
Good Luck
