Hi all,
I'm looking for a text editor for the N97. It should be able to open and save .txt files and also files with other extensions which are text filed. Something like jbak DEdit would be great but it seems this isn't compatible with the N97.
Anyone got any ideas?
Thanks,
Ash
ashg77 wrote:Hi all,I'm looking for a text editor for the N97. It should be able to open and save .txt files and also files with other extensions which are text filed. Something like jbak DEdit would be great but it seems this isn't compatible with the N97.
Thanks,
Ash
X-Plore has a good text editor built into it.
Also Petnetti LightNotePad does editing up to 200kb max . Advantage , compared to native Notes : storing files can be done on MassMemory or MemoryCard instead of device memory .
😊 Regards jApi NL
