Hi .
i got a little problem here ..
when i go to general settings of Nokia PC Suite i put a mark on "Notifications for incoming calls in the Windows Notification area.
Notifications for incoming messages in the Windows Notification area.
and Battery Level"
but when i press " Check the Notifications supported by this device: Nokia N81"
i get a red mark on both notifications for incoming calls & messages
and when someone calls me while im connecting my device to the computer through the cable his/her name doesnt not appear on the screen and i cant answer it on the computer + i cant call a contact from PC Suite !
so please anyone knows how to solve this problem Reply " ASAP" !!
Thanks !
Once you connect your phone with Nokia PC suite 7.1.40.1, In File Web Settings Help, Select Settings, In Settings, again look for an option called Settings,in this check for General, Notification Options, there you will have options for new call, sms and battery settings. Now you can check if your connected device supports these features using Bluetooth and Cable as well. If it is supported, you can click the options you want(say if you want a notification wheneve a new sms is received, click for notifications for incoming messages in the windows notification area). I think by default these options are not selected becuase selecting these options will increase energy consumption of your battery. To conclude, if your connected phone supports these feature and if you want to get notifications whenever new call or sms comes, then you can check the appropriate features on this settings.
Please do check these boxes only if you are really in need of this feature as it consumes more battery which will resulut in more energy. Save Earth Dont use if you dont want this feature
You cannot receive calls through PC, its just notification only 😃
