STRANGE BEHAVIOUR
2 replies · 2,100 views · Started 15 March 2003
Has anyone else experienced 'strange behaviour' with their P800?
Mine has started dialling 5555's and 1111's every now and again and my battery level when from full at midnight to zilch at 9 the next morning although it wasn't used during this period?
With the flip closed it also shows 'speed dial' in the window but I have nothing in my speed dial as I hear this causes problems when trying to amend the contacts?
Have you checked if your GPRS is alwyas on ? this can cause the battery to have shorter life.
Also if IR is always turned on.
Regarding the rest of the problems -- I suggest you try to calibrate the touch screen, or remove the flip for some days & see if it steel dialing 5555 or 1111 by itself
My P800 also went from full to empty overnight. I had no GPRS turned on or anything else. 😞
