Note "Note Found" on all apps that i've installed
8 replies · 2,519 views · Started 15 March 2003
why this happen
what i did is i format my 9210i then put all the new programs installed on the memory card that i just bought and this problem occured ?!?!?!?!?!
Before you installed them on the MMC, were they originally installed on the device? Perhaps the links still looks for the apps on the device in stead of the MMC... or your MMC has some problems.
[edit] or did you accidentily bought a SD card instead of a MMC card? [/edit]
[quote="unsound"]Before you installed them on the MMC, were they originally installed on the device? Perhaps the links still looks for the apps on the device in stead of the MMC... or your MMC has some problems.
[edit] or did you accidentily bought a SD card instead of a MMC card? [/edit][/quote]
i already formated my 9210i bfore i installed the apps
and yes it's a MMC not SD card
Look below
[quote="The Godfather"]Be shure they they are not installed in your 9210. Try formatting your mmc and re installing them. Let us know... :P[/quote]
i don;t know why but after an hour or so the apps is working perfectly and is this problem cause by i;m not formatting the card first ???
but not the only apps that still note not found is MGS -- MVRpool and gadget golf
so i deleted those 2 and now all apps works like a charm but for MGS after i try to reinstall it even on the C: drive the note not found still exist so i deleted again
but i haven't tried for the gadget golf
Are you using any Localization software on your device, this hapen to me once, you can only disable localizaton, you don't have to uninstall it.
[quote="Anonymous"]Are you using any Localization software on your device, this hapen to me once, you can only disable localizaton, you don't have to uninstall it.[/quote]
(Sorry, that was me. I forgot to log on before)
The localisation software is a 3-rd patry application, that can be installed on 92x0. The developer is Psiloc.
It helps you define let`s say rusian characters keyboard layout for your communicator.
It is not a bult in app. 😉
