Hi All,
Did anyone had the problem with camera software won't open (both by pressing camer button or running it directly from the menu)
I've tried *#7.... nokia magic codes but it does not make any difference.
How can I get 6710 phone back to "out of box" state at all?
Many thanks for your help
Also found that C: drive is inaccessible on the phone for some reason - so that's probably why but not sure - any way phone needs to be reformatted but dono how?
did all you've mentioned above - it restarded phone to factory settings and removed all data but camera still won't start.
jApi NL wrote:When it is an original Nokia you can do a Reset according to my post here :
http://www.allaboutsymbian.com/forum//forum/thread/81021/
Or :
http://www.allaboutsymbian.com/support/item/Sorting_out_an_endless_reboot_cycle_after_rogue_application_install.php
Hard reset deletes all personal data , so a backup is advised .😊 Regards jApi NL
That sounds sad . When the software is completely resetted , I think there is only one conclusion : hardware is broken ? So it probably needs fysical repair .....
😊 Regards jApi NL
