Skype Symbian in beta - fully featured native client
16 replies · 7,392 views · Started 10 December 2009
Skype has released the first beta of its own native Skype client for Symbian phones. The Symbian Skype client supports a full range of Skype functionality including Skype to Skype calls, Skype Out calls, instant messaging, file transfer, credit top-up, voice mail access and more. In the beta phase a limited number of S60 3rd Edition Feature Pack 1 and 2 phones are being support. Compatibility will be extended to other phones in due course. Read on for screenshots and additional information.
I installed it on my micro SD card instead of the phone memory. I signed in and checked it out. I think i'll stick to the new Nimbuzz 2.2 though. I barely make VoIP calls though so don't take my word for anything - i have no 3G on my Nokia N85 b/c of a frequency non-compatibility issue.
Yes power users might want to stick with Nimbuzz / fring etc. But the Skype client does have the sense of familiar / simplicity going for it - better for the less techy users?
Fring and Nimbuzz always lagged during skypeout calls. I wonder if this native app would lag during skypeout calls.
Why aren't you allowing comments on the Lee Williams interview?
Is it because it was horrible puff piece, about a man who is in complete denial of all the issues facing Symbian? No problems with the UI, no problems with the underpowered hardware? Really?! Even Nokia have moaned about the first and held their hands up on the second.
Admin note: Have added comment thread - not sure what went wrong - suggest people email me rather than comment on another thread. And the point of the piece it is a transciption of an interview with Lee Williams putting his point across.
Sadly enough its not working on the E72 😞
It does everything except that correspondents cant hear eachother
My big problem with Skype (I've always used SIP for VoIP) is the fact that it's a peer-to-peer technology, so instead of investing money in those pesky expensive server farms like Google and other IM/VoIP services, it uses my bandwidth and my computer resources when I'm not using them. (If you don't believe me, try leaving the Skype client running on your PC with nothing else active, then settle down to watch the telly but with your modem and Task Manager in view: within half an hour your modem lights will be flashing like crazy and half your PC resources will be being used.)
Sooo... my $64,000 question wrt the Skype mobile client is whether it does the same thing? If I leave the client running on my handset, will it be gobbling up my bandwidth, battery and resources while the bloke down the road is Skyping his family in Pakistan?
Not good loking
No notifications :icon4:
No calls possible (I hear only the noise)
on my N86. Nimbuzz is 1000times better
The current beta of Skype for Symbian works on my E71 (with new firmware installed last week).
Here are my experiences:
- Overall voice quality was very good.
- There were some cutouts for 3 seconds of the two-minute call.
- There was a delay of about one second when calling from Skype PC client to the Skype Symbian via 3G connectivity.
- The Symbian client does not yet integrate into E71's call management functionalities, which means that you cannot answer as usual with the green button or with bluetooth handsfree or some other headset. You can answer to a call only with the left context button, "Accept".
All in all, the new Symbian client works clearly better than Fring, which I tested a couple of months back and found it unsuitable for any real-life use.
Next week, I will test this:
- Calling between two E-series cell phones via Skype Symbian clients on both
- Calling from Skype PC client to Skybe Symbian client via WLAN connectivity
NO LAGGG!
Unlike numbuzz and fring there is no lag during skype-out calls. Its perfect over WIFI and works great on 3G.
I'm sure with a future version this native skype app would be perfect.
@ neilhoskins
You must be using Windows, because I have never seen anything like that on linux. I use Debian GNU/Linux and Linux xlient has never caused anything like that. Are you sure that your windows system is not infected by virus, trojan or something like that?
"You must be using Windows, because I have never seen anything like that on linux. I use Debian GNU/Linux and Linux xlient has never caused anything like that. Are you sure that your windows system is not infected by virus, trojan or something like that?"
That is how Skype works.
http://www.skype.com/help/guides/p2pexplained/
A true P2P system, in our opinion, is one where all nodes in a network join together dynamically to participate in traffic routing-, processing- and bandwidth intensive tasks that would otherwise be handled by central servers.
The high resources use by Skype is why some universities and companies ban Skype.
Thanks for that. So does anybody know the answer to my question? Do my handset resources get gobbled-up by other Skypers, or maybe mobile users freeload off PCs on landlines. Either way, I think I'll be sticking to SIP.
Sadly as someone already said, not working on Nokia e72. Simply can't hear each other. When starting a call i hear dialing on loudspeaker but when it comes to ringing all sounds stop, can't hear in headset neither called person can hear me. Shall this be fixed?
Tested IM, VoIP call, send/receive files. Everything works fine. I don't know why these devices are not listed...
