Getting SIP client work over GPRS, not 3G
1 replies · 9,051 views · Started 19 December 2009
Hello,
I have setup the integrated SIP client on my Nokia N95 8GB and it works fine. But it looks like there is an internal software limitation that you can make or receive calls over the Internet Tel. only when you are connected on 3G or Wi-Fi network. When you connect over GPRS the client registers successfuly to the Call Agent, but does not receive calls, also when you try to make a call it tells that Internet Tel. is not registered.
I thought that there may be some small patch or application that can "fool" the Symbian that we are connected over 3G or Wi-Fi so the SIP Client will actually work.
I understand that 3G is way better talking to speed and latency, but in my country there is very poor network coverage supporting 3G. So i desperately need solution for this problem.
Thanks in advance!
Best Regards,
Borislav from Bulgaria
