pc connects as S60, not 5800xm
0 replies · 4,069 views · Started 24 December 2009
Hi all, this is my first post. I would like to start by saying that I really like my 5800xm. It has it's quirks, but far less then any of the other phones I've had. A quick background. I commute about an hour and half to and from work each day and have gotten addicted to my audiobooks. My problem is that when I connect my 5800 to the pc it comes up as a S60 device and not the 5800. This only started recently. The program I use for downloading audio books, Overdrive Media Console, is only compatible with the 5800 and not the S60 and works fine when the pc sees my phone as a 5800. Current firmware is v31.2.101. It worked with this update when first installed. No other updates, other then the Ovi suite (?) or apps installed since the problem began. Any solution or thoughts on this problem will be greatly appreciated.
