Technical problem with N95 8GB, experts needed..:)
3 replies · 5,365 views · Started 25 December 2009
I have updated my firmware and re applied settings from back up. I have done this about 15 times before right from when I got the phone with V10 or whatever it was back in Nov 07 with no issues. The problem is I have 4 o2 access points and it is listing them even though they do not exist.
Let me try and explain..
O2 Mobile Web is one of my access points. When I open an app and it lets me choose and access point to use it shows O2 mobile web twice even though I only have one saved. Even if I delete O2 Mobile Web it will still come up. Whats worse is if I select to use it is says conenction not valid.
Anyone know where the access points are stored in the phone (not the ones in settings as I fully understand them) but the ones that the phone gets when you open an app and it lets you choose from the currently available access points. My thoughts being I could use Y browser to go and wipe these clear so it will just use the correct ones from the ones I program in.
I know it sounds complicated but hopefully it makes sense.
Any help appreciated.
Liam
sorted by restroing and using an earlier back up. Think it was restoring connection settings that were already there. Anyway back to 100%
theres a guide on the top of this forum.
Basically get an up to date pc suite and back up everything. Then click update software and it will take you through it.
Read the guide though to avoid damaging the phone.
