help to get flash player for E71
5 replies · 11,180 views · Started 26 December 2009
[SIZE="4"]can anybody give me direct link for adobe flash palyer for E71
I have tried a lot, but i couldnt get it
thanks[/SIZE]
thanks,
yes its included, but maybe its outdate
i have tried to log to a teamviewer through my phone but it give message you need to have a flash player
altaher wrote:thanks,
Yes it's very likely the flash viewer on the phone is out of date, and there's no way to update it, so you'll just have to give that website a miss.
n73diary
Thank You very much, yes it works fine with e71 and the adobe is update thanks for that
yet still i couldnt run the program (teamviewer.com) which will enable you to remotely admin a PC - maybe it need the latest adobe flash player
any how thank you very much for your support
