Setting Wallpapers to fit the Left Bit?
6 replies · 2,648 views · Started 16 March 2003
Can anyone please tell me how when you have set the wallpaper to get the left bar bit to also display the rest of the background image?
As you can guess I am new to the 9210 Communicator and can't figure it out.
Thanks in advance for any help.
Shahbaz
This is done by creating a display.mbm and replacing the old one.
Checkout skins at http://nokia.warlocks.be and http://loonyworld.adsl.dk
They pack a display.mbm file, after you've replaced your old display.mbm and rebooted you will see it appear on the right side.
[quote="Dazler"]This is done by creating a display.mbm and replacing the old one.
They pack a display.mbm file, after you've replaced your old display.mbm and rebooted you will see it appear on the right side.[/quote]
Ah right. Thanks for your help.
Shahbaz
I'm sorry just saw you ment LEFT bit ...
It still isn't possible to set the left side of the 9210 interface.
You cna only change the right side and the background in the Desk app ...
[quote="Dazler"]I'm sorry just saw you ment LEFT bit ...
You cna only change the right side and the background in the Desk app ...[/quote]
Yeh - sorry I meant the right bit - my apologies....
Shahbaz
Hey guys try to get the sides right 😃 This is at least the second thread were the sides get mixed up 😃
