Nokia e63 and e71
2 replies · 5,328 views · Started 27 December 2009
Iv gone through the full set up both manual and automatic to set up wlan connection with my sky broadband . The mobiles connect a couple of times then I get the no gateway message. Can anyone help with this problem please as its getting annoying now. Many thanks for reading.
I have a dim memory of something similar, when the default SSID is used, as it's the same as a local one. It feels unlikely... but might be worth a try?
Cjp wrote:Iv gone through the full set up both manual and automatic to set up wlan connection with my sky broadband . The mobiles connect a couple of times then I get the no gateway message. Can anyone help with this problem please as its getting annoying now. Many thanks for reading.
If you have the original Sky moden (Netgear DG834GT - white one), I couldn't find a way under WPA . Change to WEP and you should have no difficulty.
