Tips for searching for apps
0 replies · 4,515 views · Started 27 December 2009
Since it's been a low-posting holiday weekend and I'm sure that everyone has time on their hands, I thought I'd post a helpful tip.
On the AAS S80 forum another poster once asked me how I was able to locate so many new applications for the 9300.
The trick is to tell your search engine what to exclude.
For example, I use Google and will often use a search string like:
N97 download -games -ringtones -themes -torrent -rapidshare -wallpaper -reviews
This pretty much gets rid of the common "junk" and warez-type sites from the search results.
I also search with Symbian, S60 5th, 5800 and J2ME varients which can bring up sites which don't have N97 specifically listed yet.
Now if I can find a way to exclude those pesky aggregator sites from the search results--you know, the ones that composite links from elsewhere to try and get you to look at their ads.
Enjoy!
