NIMS on http://fp.somewhere.f9.co.uk/n9210
24 replies · 6,122 views · Started 17 March 2003
Is it just me or do only the links to nims linked to http://fp.somewhere.f9.co.uk/n9210 work but not the nims linked to http://www.somewhere.plus.com/n9210/ on the site?
Ain't that n9210 website dead? I uploaded some new nim's about 2 months ago and they ain't appeared yet 😞 , whats going on there? :roll: :roll: :roll: :roll:
Got a few 100 more to upload 😃 😃
Both those sites seem to be dead, as does www.n9210.co.uk does anyone know any good resourses for NIM files, i'd make my own using Nokia MM Converter, but it's a pain in the arse ripping DVDs and the like.
I wouldn't mind having some of your DVD nim's. 😃 would you consider dealing with some of my F1 nim videoclips, :roll: I have 100's of these, are yours full movies converted with multimedia PRO convertor?
:roll:
DVD2AVI converter, then using Nokia Multimedia Converter to NIM, but I haven't done a whole DVD Film yet as it takes 5 hours+ to covert to Avi 😃
I will do sometime over the weekend though 😊
any details of were to get this DVD to AVI convertor? :roll: and I can't convert AVI clips with Nokia MUltimedia Pro convertor, I keep on getting the error message 😞 , how do you do it?
I would like some of your DVD converted movies, pleeeeeeeeeeeeeeeeeeease :roll: 😉
Ok, any requests?...I can upload to a server for a while?
As a rule of thumb anyway 1 minute = just over 1mb does that sound about right?...I've only just got the 9210i so i'm still playing.
What settings do you use for Nokia Multimedia Pro?, and i'll do it in that for you.
got a 78mb Hackerz nim from divx DVD rip
Didn't take to long to convert from DivX.
Haven't played it yet 😃 Only have 32mb 😃
[quote="Jordan"]Ok, any requests?...I can upload to a server for a while?
What settings do you use for Nokia Multimedia Pro?, and i'll do it in that for you.[/quote]
Message from 4u2nv, because I can't login due to a F**kin error message everytime the correct password is typed in!
:x
I'd love a few of the movies, tell me when u upload and i'ii be ready to download them asap, 😉
And the best settings in mmc pro are:
Screen size = 128
Quality = 4-5
Ftp rate = 7.5.
If you want 100's of F1 videoclips don't hesitate to ask. 😉
:x
Screen size = 128
Quality = 4-5
Ftp rate = 7.5.
The settings you'll have to find out for yourself Jordan because I for one won't watch any 7.5 fps movie!
I go for 10fps and 3-4-5 quality, I use a bit smaller screen ...
This is funny, it says on screen not logged in but when message is posted by name comes up! And I have no cookies saved onnmy laptop! :roll: :roll: :roll: :roll:
I puzzzzzled :roll:
With 2000 without cookies I have to check the "enable automatic login" when logging in.
I suppose this is phpBB error since php works equally well with or without cookies
I keep on getting the error page after typing the password and submitting, then I have to type the url in again and it logs in! :roll:
[quote="Dazler"]The settings you'll have to find out for yourself Jordan because I for one won't watch any 7.5 fps movie!
I go for 10fps and 3-4-5 quality, I use a bit smaller screen ...[/quote]
I go for the larger screen size, and smaller fps rate, as the 9210i screen is small enough, u want largest possible size with fairly good quality, my F1 clips look great with this combinaton.
But then again I guess its a matter of personal preference!
this is pissin me off :x :x , now I keep on getting the following page when posting message, I think its why my messages appear twice, after several refreshes! :x
[quote="Dazler"]got a 78mb Hackerz nim from divx DVD rip
Haven't played it yet 😃 Only have 32mb 😃[/quote]
Its me 4u2nv, problems login again! :x
I have a few 128mb mmc's,! :roll: :roll:
the error seems to be provided by your proxy server.
I can't send you the file because it's way to big 😃
