can someone pls tell me htf im supposed to acces me apps after i have put them on me fone via usb using the tutorial because all it is is copy and pasting the file into my memory card how do i install the app after??😡😡😡😡😡😡:mad
my 5800 free apps
If I remember correctly, there should be a File Explorer of some kind in your Applications folder. Use it and go to the directory that you dropped the install files into and run them. That should install them.
