PC browsing Comm error
3 replies · 2,416 views · Started 11 October 2001
Oh boy i am just 1 for problems.
I have found this problem on 3 pc so far.
Running win98, NT, 2000
PC suit works but if the autolock kicks in it kills the connection and after that when ever u try to browse the Communicator it crashes.
I have tried everything from uninstall, then del all the files reinstall etc, but just can not get it to work again.
The sync still works 100%
Anybody have any ideas?
As far as i know it is indented that if your 9210 locks while connected, the connection closes. (for security reasons)
At least this is normal with psion+psiwin
So even syncro shouldn't be possible, i think
I have exactly the same problem. File transfer worked only once and has never worked since. The communicator aso disconnects from time to time. Synchronization works 100%. I a running Windows ME.
Anyone?
Wow, i can something positive!
Yippy!
Anyways downloaded the new PC Suit from nokia http//forum.nokia.com/main/1,6668,5_2_4_1,00.html and the browsing the Communicator from the PC works again.
Spent abit of time trina break but hy it looks like its really fixed.
