Bluetooth and memory Card
2 replies · 5,345 views · Started 01 January 2010
Hi im now to the site but its very helpful so far
i got the nokia 5800 and wanted to send over all my pics music and videos from my motorola E8 but i cant change the bluetooth settings to store the files on the 8gb meomry card instead of the pkhone memory. how do you do this
Any help appreciated
Bluetooth files are listed in Messaging .
In Messaging > Options > Settings you can set the Messaging App to Memorycard . This saves the Phonememory . But the files are still filed in Messaging .
After opening the file you can store them to MemoryCard . This goes file by file , however you can send multiple files . Now you can retrieve them in FileManager and Gallery .
This is a lot of work . The easiest is to copy the files to a PC and copy back to the new Card . Use a Cardreader or USB cableconnection . Select Masstransfer on your Phone .
The alternative is Nokia PC Suite (search via Google) . This must be installed on the PC first .
Hope this helps .
😊 Regards jApi NL
Is there anyway to to mark all the files and save them without opening them all individually???
If there is how do you do it.
Thanks for the help so far
