After sending and receiving MMS...
2 replies · 2,187 views · Started 17 March 2003
After Sending and receiving MMS does your GPRS turn itself off or remain on? Mine remain on which I find annoying, shouldnt it auto disconnect? Do we have to manually disconnect it evrytime we send or receive mms?
Same with recieving/sending MMS over CSD like i do - it stays on, then just times out to the settings you've made. Unfortunately, the shortest timeout for both GPRS and CSD connections are 2minutes 😞
