hi, i have a nokia 5800 and was wondering if someone could recommend a good satnav software that has door to door voice guided driving and DOESN'T use the internet to download content as you go as i don't have an unlimited data plan so it would work out to be quite expensive.
i know there is nokia maps at the mo, but that is quite expensive to buy the driving bit, so just wanted to know what else was out there.
thanks
rajanm1 wrote:hi, i have a nokia 5800 and was wondering if someone could recommend a good satnav software that has door to door voice guided driving and DOESN'T use the internet to download content as you go as i don't have an unlimited data plan so it would work out to be quite expensive.
i know there is nokia maps at the mo, but that is quite expensive to buy the driving bit, so just wanted to know what else was out there.thanks
You can try Garmin XT. It has a Symbian version compatible with xm 5800 as well.
Here is a user recommendation for Sygic Mobile Maps on a N97 :
http://www.allaboutsymbian.com/forum//forum/thread/91915/
😊 Regards jApi NL
