1st of all you cant measure a sat nav accuarcy by how quick they get a lock or where they can get a lock
the reason your nokia phone can gte a lock in the basement and the garmin cant is because the nokia phone probbaly used agps to get a lock
2nd garmin standalone units have no way of measuring how acurate they are apart from the map display to a side turning or something simmilar with nokia phones you can go into gps data application and check the accuarcy , if you do so while sitting in your basement i can allmost bet my house that the accuarcy will go something like this -- 37m -- 69m -- 178m -- 222m -- 57m -- 145m-- 34m all within the space of around 30 seconds max , that is not acuarte , yes it is just about holding a lock that the agps has given it , but signal will drop and it will show this in the accuarcy readings
if you drive with the phone and the garmin next to each other they will probably provide very equal results allthough the map refresh data on nokia can be a bit slower due to the 434mhz processor running a phone and sat nav
3rd nokia phones with weak gps signal when tested with the gps accuarcy application under most conditions , n97 , n86 , both phones share the same gps design with the antenna near the back f the phone around the camera module , both suffer heavy interference and need fixes out of the box , i went through 4 n97s and 2 n86s before having to buy a samsung to get acurate gps , i also found the 5800 to show me off destination by about 50m when i looked at the gps data it was jumping around allthough not as much as the n97 and the n86 , the n97 mini allthough better then the n97 and n86 is very weak still and when taken indoors signal will jump around like mentioned above
i now own the omnia hd and i can get a 12m-17m lock indoors constant outdors it is so accuarte its unreal
my last decent nokias for gps was the n82 and the n96 even the n95-1 with the keypad open was better then the n97 , n86 , n97 mini , 5800
i love nokias and have ordered the n900 to try out as i like new evolving products and iam hoping the n900 gps doesnt let me down like most of the recent nokias ive tryed
i use the gps everyday in my phone and i agree my n96 was better then my garmin unit as is my omnia hd but some of nokias latest efforts leave alot to be desired in gps stakes and accuarcy of the gps chip or the results its producing via the gps data application
n0k1a wrote:Very interesting topic, and one with which I've had a good bit of experience (including working with high dynamic GPS telemetry units and such, well beyond the consumer level). What boggles the mind of someone like me (with RF and engineering background, mind you) is a comment that Nokia need more sensitive GPS chipsets!
I can only conclude that such a comment was made by someone who has not used an LD-3W, or an E71, or a 5800XM. I have a 'proper' Garmin handheld GPS unit, complete with WAAS support. Comparison? There is none. Lock times are similar if AGPS is not used, as is to be expected (as any chipset without a network connection will have to receive the almanac and ephemeris data from the sats themselves, which takes time). Once AGPS enters the mix, the Garmin is left in the Nokia devices' dust in terms of lock time.
In terms of sensitivity, the Garmin is outclassed almost indescribably by all three Nokia devices. The Nokias will all easily obtain a solid position lock in a remote part of a given basement, where the Garmin is absolutely incapable of receiving even a single satellite. In some real-world, side-by-side geocaching usage, I found that the Garmin (even with the advantage of WAAS) would lose lock totally with just a little bit of tree cover, while it was almost impossible to lose a lock with the E71. In practice, the vastly higher sensitivity of the chipset in the E71 led me to multiple caches before a much more experienced cacher with a more recent and expensive Garmin unit as well.
Yes, the newer dedicated GPS units are tending toward more sensitivity, but they still lack the network connectivity, and thus will take longer to get a lock under almost all circumstances. They also lack nearly all of the other converged features of a good smartphone, requiring multiple devices to be carried rather than one, and offering few real advantages over said smartphone.
OK, from personal experience, I have seen that the E75 is not quite as sensitive in GPS terms as the devices mentioned above, but it still easily blows away the aforementioned Garmin unit.
Which Nokia devices are being regarded as not having sensitive GPS chipsets?
