Hi.
Last week I bought a new Satio, but later I noticed that streaming WMV files from the Internet was not possible.
Is there any way to stream and play .WMV files by installing some kind of plugin?
If yes, which one is the best one to use?
Greetings,
CoopKex.
CoopKex wrote:Hi.Last week I bought a new Satio, but later I noticed that streaming WMV files from the Internet was not possible.
Greetings,
CoopKex.
What network are you using? certain networks will not support video streaming over HSDPA
I'm using either 350 kbps 3G (I think) or 8 mbps WLAN, depends on where I am.
When I try to stream the clip(s), it says:
???videoframe.prompt.wrongbandwidth???
Greetings,
CoopKex.
