Im using a 3Com USB bluetooth dongle. I have paired my p800 with my PC with no probs but the syncStation does not show any bluetooth COM ports on the List.............
Any ideas anyone ?? :roll:
Try this thread
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7855
i agree w/ guest i don't have an option to check either in msrouter allowing you to connect via bluetooth, can anybody else help?
As long as you can sync, backup, transfer files then there is no problem there. You see what probably happend is you have different set of drivers for your bluetooth dongle which allows you to connect directly to the P800 via comport connection. Most of cant which is compensated by mroutes way of connecting. When you have an ENABLED Comport connection via bluetooth on your bluetooth places, all you will see on the Mroute will be an ordinary comport connection.
try disabling your 56k modem, this is what worked for me!
lol not a great solution!
This is because the p800 software was trying to use the same com port as your modem.. equally changing the com port for the bluetooth serial connection to the next available port would have allowed you to connect...
