Mail Box for Google Mail does not work in HD i8910
1 replies · 7,159 views · Started 13 January 2010
hello there,
I am nelson from Portugal, new in here and would like some help on how to get my mail box from google to work on my omnia hd i8910. I have anothe e_mail account from work and I can access it easily, but not to my gmail account. Pls help. Thanks
Hello
My English is very bad!
Hahah,,,
Here is information:
To configure IMAP for your Symbian S60 device, just follow these steps:
Enable IMAP in your Gmail settings.
Select 'Messaging' > 'Options' > 'Settings' > 'E-mail' > 'Mailboxes.'
If you have never set up email on your phone before, select 'Yes' to define a new mailbox. If you already have other mailboxes, select 'Options' and then 'New mailbox.'
Select 'Start' to begin the setup wizard.
Select 'IMAP4' and then 'Next.'
Enter your full email address (including '@gmail.com'😉 as the email address and select 'Next.' Google Apps users, enter your full address in the format 'username@your_domain.com.'
Enter 'imap.gmail.com' as the incoming mail server and select 'Next.'
Enter 'smtp.gmail.com' as the outgoing mail server and select 'Next.'
Select the appropriate access point and then 'Next.'
Enter a descriptive name for the email account mailbox name.
Once your mailbox is set up, select it from the email mailbox settings screen.
Select 'Connection settings' > 'Incoming e-mail.'
Enter your address (including '@gmail.com' or '@your_domain.com'😉 and password.
Select 'SSL/TLS' for your security (ports) and define your port as '993.'
Select 'Back.'
Select 'Outgoing e-mail.'
Enter your email address (including '@gmail.com' or '@your_domain.com'😉 and password.
Select 'StartTLS' for your security (ports) and define your port as '587.'
Select 'Back' and change any other settings according to your preferences.
Check our recommended client settings, and adjust your client's settings as needed.
