@ Steve Lichfield
Steve, if it's now getting the to level where you recommend we now consider ditching PC Suite, and moving over to Ovi Suite, perhaps you'd also care to recommend what I then use for:
a) My simple one step Video Conversion needs, and:
b) What I use to BULK manage my contacts.
CLARIFICATION, before you begin to respond mate...
Firstly, I am more than aware that BETTER Video file conversion utilities exist for ME, to do more, such as Handbrake, Quicktime Pro, etc. etc. I already DO use these, for more intensive/advanced stuff.
But for simple video conversion, you cannot beat Nokia Video Manager. Nor would I even DREAM of recommending to computer-not-so-literate family and friends, that they attempt to learn Handbrake etc, when all they want is a simple quick acceptable conversion of a Video Format, over to their phone.
And for (b), let me also explain...
With PC Suite, contacts are managed in a much more usable COLUMN based manner. Amongst other things, this allows me to do speedy, simple multiple contacts deletes, multiple contacts grouping, and best of all, by utilising the NOTES field, and having this populated with the name of the Contacts Group I need, I can in no time at all, load up my contacts, sort by "Notes", multiple select all those with the same Notes Tag (i.e Caller Group name) and then add them to a Caller Group in seconds with a right-click on the multiple selected entries. Thus meaning that no matter what phone I move to or from, I can keep my Caller Groups intact, as some don't allow this using the Switch/Transfer Tool (and this is just an example of one such area - there are many more that this column based management gets used for).
ALL of this sort of thing is removed in Ovi Suite, with it's much simplified (sanitized if you will) interface and approach.
And forgive me, but were you to say, that's the selling point with Ovi Suite - a more sanitized, simplified approach, making it 'easier' for users, how does having to learn a whole new advanced Video Conversion Tool fit into that philosophy...?
For sure, this rant is not aimed at you, but by commenting that you are near ready to recommend that people move to Ovi Suite, then one of us has to pull you up for the massive shortcomings in such a recommendation.
Unless and until (which I doubt they will EVER do), Nokia allow proper Contacts Management, and include a simple Video Converter, then Ovi Suite will NEVER EVER be a tool I can use to replace PC Suite.
But Nokia are not listening, despite me repeatedly telling them all this direct (NDA's prevent me saying any further, in terms of where future versions are headed).
So PLEASE Steve, not only wholly reconsider your comments, but use your influence with Nokia (public profile, if nothing else) to point out these shortcomings to them, as it's clear they are wholly aware, but also completely not bothered...
