hi does anyone know how to resize a photo to send on mms? On the good old n95 once you'd picked your photo and added it to the mms message and it was too large it would ask if you wanted to resize it so that you could send it. The n97 doesn't seem to have that option any ideas?
Cheers
If you select the photo in question, select edit, then add effect, then Decrease Size this will give you the options available to make it smaller.
I think if you set:
Messaging, Settings, Multimedia message, Image size = Small
(I think the default is large)
It will resize images to small before sending as MMS. I have this set, and when I take 5 MP images, they send by MMS fine. No need to resize manually.
Thanks for the replys fellas that has sorted me out. Sometimes you just miss the most obvious thing!
Ta
my n97 resizes the photo automatically just like my n95 did. are you sure yours isnt doing the same?
