Unable to connect to Laptop via USB Cable
3 replies · 13,936 views · Started 18 January 2010
Whilst trying to update my music via Nokia Music Store/Ovi over the weekend somehow my Laptop stopped connecting with my N95 8Gb. It keeps telling me that the drivers required to find my device are missing. I'm using the cable that came with the phone.....the connections are clean and free from any debris and it worked earlier in the evening. Does anyone know where I can get a driver so I can connect my Nokia N95 to my Laptop via usb cable?
Please please help.
Jase
I'd try un-installing and re-installing service suite and ovi. All the usb drivers are installed with the nokia software.
Do have backup of your phone data & PC registries then Uninstall Nokia PC Suite, Nokia Connectivity cable driver, PC Connectivity solution, Nokia flashing cable driver(if any on your PC), Run PC Suite cleaner and reliable PC Cleaner too. Install latest Nokia PC Suite from www.europe.nokia.com/pcsuite or Nokia OVI Suite from www.europe.nokia.com/ovisuite, reboot your pc. Once pc started, connect your phone with USB in different ports of your PC and check
