Escarpod to be integrated into Symbian^3 and Symbian^4 ?
11 replies · 3,138 views · Started 18 January 2010
Escarpod, the third party Open Source podcast gatherer and player, originally written for UIQ and available for S60 in beta form for a while, is now the source of a Contribution Proposal to the main Symbian Foundation code base. Effectively, this means that future Symbian devices will have a podcast client even if Nokia choose not to install their own proprietary Podcasting application. Read on for links and more information.
Good news, I am using this at the moment on my i8910 because the built in Podcasting app has never worked. It never updates after the first time they are added. SAMSUNG PLEASE FIX THIS!!
I miss Podcasting and music player integration supplied in Nokia's but I wouldn't trade my i8910 for anything else currently.
Back to escarpod, the best way to describe it is functional and basic but it works well and a definite download for Satio and i8910 owners.
The current version of Nokia's podcasting app has a serious bug in which it does not "hang up" the wi-fi connection after use, meaning that if it automatically syncs in the morning, you have to make sure you manually disconnect or it'll eat your battery. It renders it rather useless. A previous version is available on their site but it only works on S60 FP1 or earlier due to certificate errors.
So essentially, good riddance. Nokia podcasting was once good, but it's poorly supported and rather difficult to use. It needs to be replaced.
I'm getting sick of Nokia Podcasting on my N97 (v20) and another serious bug. It corrupts downloaded files, often reporting 110% downloaded, and more! For MP3 podcasts this often results in annoying glitches and frequent repeated repeated playback. For video podcast you end up with an unplayable file. (Downloading the same file using the built-in web browser and the same WiFi connection is fine, even if the download does sometimes get paused.) I reported the problem to Nokia but I don't hold much hope of them ever fixing the problem. What I don't understand is why no one else seems to be shouting about this issue.
EXCELLENT Steve can you keep us up to date then I can buy an E72. I cannot understand why Nokia should have dropped this it is my most used application - all the time when I am travelling on business.
@Unregistered (last one) You're misunderstanding. Escarpod is already available for S60, so you can go ahead and buy your E72 and download it for that. The point here is that it will become part of the platform and will be one of the built in apps.
Per subscription settings are essential for me.
iTunes eventually added support for this and I find that's the way I do podcasts for the time being, along with music using iTunes Sync. For one subscription, I download all new and keep all, for another I only want to download and keep the latest. Others I want to manually select which episodes to download.
I'd much rather manage podcasts on the device though.
Sockatume wrote:The current version of Nokia's podcasting app has a serious bug in which it does not "hang up" the wi-fi connection after use, meaning that if it automatically syncs in the morning, you have to make sure you manually disconnect or it'll eat your battery. It renders it rather useless. A previous version is available on their site but it only works on S60 FP1 or earlier due to certificate errors.
I agree it's a bug and should disconnect, but I keep my Wi-Fi connection on permanently anyway - I use it for push email. No battery problems are caused by this for me.
Nokia knows that the default podcasting app for the previous phones and new phones are replaceable by selected podcasts apps available on the net =)
illusionado wrote:Nokia knows that the default podcasting app for the previous phones and new phones are replaceable by selected podcasts apps available on the net =)
Nokia knows that most of the default apps for the previous phones and new phones are replaceable by selected apps available on the net
Unregistered wrote:I'm getting sick of Nokia Podcasting on my N97 (v20) and another serious bug. It corrupts downloaded files, often reporting 110% downloaded, and more! For MP3 podcasts this often results in annoying glitches and frequent repeated repeated playback. For video podcast you end up with an unplayable file. (Downloading the same file using the built-in web browser and the same WiFi connection is fine, even if the download does sometimes get paused.) I reported the problem to Nokia but I don't hold much hope of them ever fixing the problem. What I don't understand is why no one else seems to be shouting about this issue.
The are many complaints on MyNokia website about the problems with Nokia's built in podcasting application on s60v5 devices. However, Nokia just does not react to them. I have called the local Nokia service and was told that no complain has been reported to them and they were unable to find any complains about it in Nokia's global bug registry.
Anything to do with music is a mess on the N97 Nokia better get things sorted.
