Hi guys, i had a problem here with my 5230. As far as i can remember, my phone vibrate every time i touch the screen on menu, contact, item, or else. But lately, when i touch the contact bar at home screen, i got no vibrate, and when i touch message or item inside, it vibrate with a lesser power than the normal one. I thouched the other menu and it worked fine, i tried to change the profile, and checked the vibration level, turning on and off, but still it wont vibrate.. does anyone know how to solve this? a software/harware, or maybe it is not vibrating and i just forgot that.. thx
5230 Vibrate Issue
the first thing you should do is go into your profiles and check the vibrate setting, 1, 2 or 3, for the profile you are currently using. each profile has its own setting, so it might be lower on one profile compared to another profile.
also when your battery gets very low, the vibrate will reduce to save battery. so make sure you have a full battery.
Thx for your reply.. I've tried that, changing the touch vibrate setting 1/2/3 for the current profile and tried the others too, it doesnt help.. The battery is fully charge too..
But am agree with battery issue related with vibrate, my old 5300 vib is reduced when the battery get low, but this touchphone seems different.. Its only a few days penetrated with sim card.. 😞
