Found this available for pre-order on P800er,
http://www.p800er.com/product.asp?id=23
MS Duo-CF Adaptor
Flash to Duo or Duo to Flash?
It's the 'wrong' way (i.e. wrong for us P800 Duo users!) - converts Duo cards into CF cards, so you can use an MS Duo in a CF device 😞
Then I have no use for this. :-?
[quote="simion_levi"]It's the 'wrong' way (i.e. wrong for us P800 Duo users!) - converts Duo cards into CF cards, so you can use an MS Duo in a CF device 😞[/quote]
OOOHW SHITE!!!!
I almost thought i could use it in my P800...
thanx for the warning...!
damn...
Well presumably if you have a CF Digital Camera you could put your DUO in it, take some pictures then transfer it to the P800 to view them at 4800 colour resolution, 320 x 200.
... er ...
Yes, OK, it's useless to you :roll:
