Quick Help : Ovi Maps on Satio (issues/doubts/guides)
7 replies · 37,676 views · Started 21 January 2010
Hi There,
...The thing is i'm desperate to have OVI MAPS on my Satio, hence Google Maps needs contant GPRS to work with. and now i'm very much in need of having an Offline Map program with me all the time.
But guess i'm stil not sure if its gonna be a good idea to hack Satio in order to install Ovi Maps in it, therefore here are my doubts about it:
(Please be patient with me, as i'm new to the hacking topic)
1: Appearently i have to SIGN the HelloOX2 with help of a chinees website (called as OPDA or OPTA), at the first step they will obtain my IMEI and afterwards they'll send me a CER & a KEY. that later i have to Sign my HelloOX2 before sendint it to my phone.
Yet i'm not sure if its a safe idea to give away my IMEI, i've read a couple of stories about theft IMEI's, So do you think if i could trust OPDA? or it they ever try to abuse my IMEI, what would be the worst scenario?
2: Do you happen to know how th hacked phone will behave? i'm hoping hacking and installing Ovi Maps wont turn my phone into a nightmare. (hence those softwares are not official and the phone is literally hacked at that point), i'm worried if hacking would decrease Satio's overal performance or KILL it at worst.
3: I've already found a hacked version of Ovi Maps (V3.01 for S60.V5), guess if the hacking proccess goes right, then i can freely install Ovi Maps on my Satio.
So despite the fact that i made a research about this matter, i'm still not sure how i can accurately do the hacking proccess? i mean, i'm still till this point that i have to LOG IN to OPDA, and they will send me a CER & and a KEY after 48hours, BUT i'm not sure what i should do as for the next step? Do you happen to know a STEP-BY-STEP guide for hacking Satio? I dont know whats the use of CER & KEY, or how i could Sign HelloOX2 before sending to my phone.
4: Finally i believe for a successful hacking proccess i'm in need of a program called as ROMPATCHER, which i should use it with HelloOX2, do you know what's that? or where i could find it? Does it needs to be Signed with OPDA as well?
THANKS ALOT in advance for paying attentiont to my message
I hacked my satio a few days ago, hasnt made my phone slow or anything. And its better because i can now install any s60v5 app 😊
Also, you only have to wait around 8-12 hours for OPDA. It tells you once you have signed up and applied for cer etc.
i used this tut: http://satioworld.com/viewtopic.php?f=24&t=49
When its hacked, if you want to unhack it just run helloOX2 again on your phone
Edit: Rompatcher installs when you install helloOX2 on your phone, so you only need to sign helloOX2
Thanks buddy,
I got it right yesterday, so its all done & working with no problems.
thanks for replying back to my question 😊
does this work for Ovi Maps 3.3 .. with the Free Navigation?
update .. I couldn't get 3.3 to work .. anyone else??
I hacked my Samsung I8910 a while ago before it got stolen and i was left with the satio. Its exactly the same process
You have nothing to worry about when it comes to doing the hack and after it. It cant kill your phone and wont slow it down at all 😊
Hope that helps
BradAll wrote:I hacked my Samsung I8910 a while ago before it got stolen and i was left with the satio. Its exactly the same process
Hope that helps
I lost my Ovi Maps after upgrading the firmware .. Hello OX2 wouldn't work on the new version.
Is there another way to do this now??
