pc suite states n82 connected non compatible mode
2 replies · 11,161 views · Started 23 January 2010
not sure if this is a repeated thread...
anyway, i just installed the N82 pc suite and i have connected my phone to my computer. installation went fine. but i can't sync or do whatever. it says that my N82 is connected in a non-compatible mode.
and another question...
is there any ways i can transfer text messages from my N82 to my computer?
please help.:con?
jApi NL wrote:Check : Instr > Settings > Connect > USB . Set it to PC Suite + Yes .
😊 Regards jApi NL
hi jApi NL, thanks! but i tried using your solution and i still face the same problem. =( are there any other ways???
