Largest mini SD card that will operate in a Nokia E75
2 replies · 9,176 views · Started 24 January 2010
Can anyone tell me or does anyone know what's the largest mini SD card that will operate in a Nokia E75?
The E75 uses microSD memorycards . Not miniSD cards , which are different from micro .
E75 is also HC = high capacity , compatible . This goes up to 32GB . At the moment 16GB are easy to purchase . 32GB will come probably this year , as Samsung lately announced . Sandisk can produce 32GB , but they won't sell them . Probably because of commercial strategy .
Class 2 are the lower speed , class 8 the higher speed cards .
16GB microSDhc class2 , class4 and class6 can be found in shops .
The class (= speed) on the card is indicated on the top-left corner , in a small circle : number 2 or 4 or 6 .
😊 Regards jApi NL
This is very nice to see.I really want this kind of site.Thanks for sharing this.Thanks to you. i also have Nokia E75 and facing the same Problem.Thanks once again.
