Temperature on nokia maps weather not in Celcius anymore?
3 replies · 5,936 views · Started 25 January 2010
The temperature in weather full details on nokia maps is showing in degrees F not celcius. It never used to be like this how can I get it back to degrees C?
Liam
Alright mate,
haven't got weather on my version,
but try Options>Tools>Settings>Map>System of measurement>Metric
BTW. my first phone was that Philips, was it a C12? I can't remember
Thanks for the reply. The thing is it never used to have simply metric or imperial. For instance I prefer MPH for speed and mile but I also use Celcius.
This is how it used to be, seems now you cant have a seperate option for temperature and speeds. I use both metric and imperial depending on what I am measuring. Must be my age!!
BTW the phone I had was an O2 Easylife and I think you are right it was actually a C12...
1998 I got it.
