.sis file won't install - any ideas.
6 replies · 18,574 views · Started 27 January 2010
Hi
have tried to self sign and install an sis file but keep getting the following error when following the following prompts
untrusted file screen - continue? Yes
then
application not compatible with phone continue anyway? Yes (i know app is s60 compatible)
finally and the nail in the provebial coffin the following error occurs
"unable to install a protected application from an untrusted supplier"
the app is unsigned and i have signed it using mobile signer - signsis
tried to use open sign beta which i have used before but it keeps erroring that the emaail is not compatible with my application file (this is at symbia signed)
any ideas on why this is occurring?
try this
menu -- settings - application manager - installation settings
a. software installation - all
b. online cert check - off
default web address - none
Jerm
unfortunately they are already set to that.
Was thinking v20 firmware introduced more stringent certificate settings
in that case, your certificate probably doesn't have enough capabilities to install into the protected system folders, etc...have you tried getting one from opda? if the site hasn't changed much i can help you to apply for one
yup you can try that too
i'll need your
a. IMEI
b. phone number
if you're comfortable in giving it to me i can help you do it, if not you can poke around the site and see if you can do it. i've done it so far for about 5 different phones with no problems 😉
