I8910 HD connection to linksys wireless home n router problems
2 replies · 7,208 views · Started 27 January 2010
so new guy here! I bought a Linksys home n wireless router to connect my I8910 hd so I could use Fring's newiest version software to use the video calling service through my Skype. The only problem is that in order to use the video calling feature you must have a 3g or Wi fi connection. The router set's up easy enough! I even connected to the router with my phone and i can see all the details to include the signal strenth etc, but once i try to start web browsing, I get the "no gateway reply" error.. can anyone help? 😮
Try disabling Super G or any range extending features of the router. Also try setting the router to use b or g, rather than both b/g. You can find these settings by logging into your router and going to the wireless tab.
I did have some similar problem ...
Try to insert the router IP address by DNS in Basic Settings.
Some routers have the possibility to write in three DNS (two are from Internet Provider) ...
Regards.
