Is there a way to refresh the list of available updates on the N97 within the Software Update app?
Whenever I go into it it loads without checking for new updates so I am not seeing the OVI Maps download.
GD
GD
gary_dexter wrote:Is there a way to refresh the list of available updates on the N97 within the Software Update app?Whenever I go into it it loads without checking for new updates so I am not seeing the OVI Maps download.
GD
In Software update > Options > Settings > Auto-check for updates (should be set to On or On in home network). Also select your Default access point.
Problem solved now.
However it is not showing up for Vodafone branded N97.
gary_dexter wrote:Problem solved now.However it is not showing up for Vodafone branded N97.
Try this method:-
