i wonder if anyone has encountered this problem. my 9210 freezes up occasionally, about 5x a week. this usually happens when i multitask in the pda. the annoying thing is, every time i reset by removing the battery, the calendar date resets to march 08, 2002. does anyboday have an idea whats happened to my 9210? i appreciate any help here. thanks
Calendar Date Resets
You can restart your 9210 by pressing Shift/Ctrl?Chr/K.
every time you hit this combination it shuts down the last used application.
So just keep on trying until it restarts.
Because it doesn't lose power, the battery stays in, it won't change the date.
