I've read the previous threads with regards to connecting the P800 to the PC via bluetooth but they haven't helped. I've got the Gigabyte GN-BTD01 dongle and it works fine with my T68i but when I try to connect to the P800 it just says "The Bluetooth Serial Port connection failed: The remote device closed the connection". Any ideas? I've paired it. Both the PC and the P800 see each other. What is going wrong? Any helpful info is well appreciated. Thank you.
Help with bluetooth connection
I think your error message is the one which is often described in this forum and which is the one you can ignore, after a moment the connection works also. Have a little bit patience.
Ciao
Christian
... as long as you have the p800 to communicate with the paired device without prompting - set in the paired settings of that device.
:agrue: :agrue: :agrue: :agrue: 😮 😮 😃 😮 😮 :agrue: :agrue: :agrue: :agrue: :agrue: :agrue: :agrue: :agrue: :agrue:
