Ovi just not working
1 replies · 2,149 views · Started 31 January 2010
Righty,
I downloaded ovi beta the other day and since then my phone just will not connect to ovi suite.
What I have done already... :-
Unistalled using cc cleaner ovi maps & nokia pc suite....done a full install individually ie installing one delting it then installing the other...still nothing
Installed non beta ovi suite - the same
I generally get the device is not recognised although did have some parent error message once...when reinstalling it does not find the drivers for the device.
Also tried without the av software running - and added it to the friendly software list
Slowly but surely giving up....any suggestions guys?
O and ive tried the reinstall then used a different usb port and still nada
Matt
honestly, i just stay away from ovi suite and stick to pc suite
ovi is just too....simple
all in all im afraid cant help you much...have you tried the pc suite cleaner before installing ovi suite (assuming you're upgrading it)? if not forum nokia may be of more help i think..
