I have noticed if you download the headers only and then select download the whole message you can then at a later download the same email to your pc without any problems. I thought this behaviour was only seen on smtp email
POP Email on breathe is good!
Can you show us what configurations you used for setting up your pop3 account? Did you use GPRS?
I believe that e-mails are POPed to our P800 without deleting the mail from it's server. Even if you download the whole mail & not just the header.
This is also possible with our existing Outlook programs. But since the default is delete the message from the server after download. The mails are in your mailbox already & can't be downloaded again.
BTW, the P800 sees mails that are still in the server. So when you do a GET & SEND, your inbox will be refreshed with what is in your e-mail server.
