Nokia E52 v31.012 firmware now available
32 replies · 8,110 views · Started 03 February 2010
A new firmware update, version 31.012, is now available for the Nokia E52. The update is currently only available via Nokia Software Updater (PC). We've not noticed any major changes, but a number of bug fixes and small version updates to built in applications (Web, Email, Music Store, Maps) are included. The phone's noise cancellation parameters have also been updated, which should improve audio quality of calls.
If this update doesn't include a Xenon flash I'm not going to bother. Until Nokia wake up and release a firmware update that includes a Xenon flash then I am just not interested.
firmware update with xenon flash?!?
What medicines you have taken?
Unregistered wrote:If this update doesn't include a Xenon flash I'm not going to bother. Until Nokia wake up and release a firmware update that includes a Xenon flash then I am just not interested.
LOL! Yeah, and give me a firmware update with a capacitive touchscreen and 256Mb of RAM for the 5800 while you're at it Nokia!
I've had a bug with my E52 that means it won't except my lock code. Has anyone else here had the same problem. Already had to send it back to Nokia twice. 1st time it happened I thought I was going mad!
Hope this update fixes it.
Was it a UK phone that this new firmware is available for? It is not showing up for my Euro1 model. I could try and change product codes to get it (seems to be available for SSA1 product codes but I'm not sure which languages that code will get me)
Not available for me (yet?)
Russian unlocked E52-1 022.009.C00.01 language code 05.01
This is not true.
For my product code (0578063) there are no new software update. This is from official Nokia site:
"Latest available software for Nokia E52, product code 0578063
Version: 022.009"
Firmware 031.012 is not available as of today in Greece, either.
Can anyone confirm if this fixes the infamous software issues (lock-ups, crashes, etc)?
There is no update available for code 5078077 Singapore models 😞
Finally v31.012 firmware is released today. I have updated with Ovi Suite.
All works fine but I don't see any huge improvements yet�
I live in Greece. Cheers
It seems to be now far more widely available via PC (not sure about OTA though). Have checked quite a few product codes, including EURO1 and most of the ones I checked are now ready. Will try to update tonight and see what happens.
The firmware ia availabre in Mozambique and i have updated my phone. Changes? The first change that you going to see after the update is the OviStore icon. Other improvements are not visible. But my phone sounded but faster now, especially the WLAN connection.
The light sensor still difficult to understand when is going to work, because sometimes is On even in very bright places.
But since i have never had problems with the phone it was hard to see the improvements
Updated firmware tonight to v31.012. User data preservation worked completely. Process was very quick and all worked fine. Can't see any real changes yet (Maps still seems to be the older version that is not free for voice guided navigation; was hoping that would be in firmware but is easily updated) but phone seems a bit quicker. Can't speak about bug fixes - my phone was working well before the update and still seems to be the same but a little faster.
It is now available in Malaysia for code: 0591705 via FOTA & Nokia Software Updater.
There is Internet Radio too. Under menu-> media -> radio.
Finally updated in Russia. Unsuccessful update with PC Suite, success with OVI suite
