Realplayer streaming access point?
0 replies · 8,618 views · Started 03 February 2010
Does anyone know if you can make realplayer ask for the access point to use each time you connect to a streaming link?
Its just at the moment when I connect to sky sports for example at home I use my home connection but when i'm at work i connect using the 3G network but I have to go into settings within realplayer each time to change the default connection. It would be loads easier if it gave you the option like the browser does! If anyone knows so way of doing it then please let me know.
Cheers
