Does anyone know if I can install the downloadable software for 9210i on my "regular" 9210 and make it work. I mean the "All_Nokia_9210i_data_SV.SIS (Swedish, SIS file, size 2.3 MB)" file ??
Software for 9210i
I don't think you can install it. From what I've read on other forums, it installs temporary files to the larger C drive, of which the 9210 lacks too much.
Also, after trying to install 4.x firmware based apps on my 3.x firmware 9210, I don't recommend it.
However, some of the 9210i software <B>does</B> work on the 9210. The software I've tried is RealOne Player (though I'm having some audio probloids with the streaming media), and the Macromedia Flash player.
<font size=-1>[ This Message was edited by TANKERx on 2002-05-02 1911 ]</font>
So you mean if i install the "ALL_ Nokia_9210i_data_NL.SIS" or other that it won`t work at al, and if it does you have al lot of problems.
but there must be a software thats working on a lower firmware?.
I have Firmware v3.62 and tried to install Firmware v4.13 on my memory card and the only problem i had was that the text was not working dit anyone tryd it or not??
