David Gilson recently performed a big feature on Twitter applications on Symbian and S60. Mind you, thanks to the feedback of AAS readers, he has now expanded his survey to now cover an eye watering seventeen Twitter options for S60 users wanting to get more out Twitter. Gulp. Read on!
Gravity is nothing short of amazing. And not just because it's the best now, but even more importantly it is continuously improving. There aren't too many s60 apps you can buy and get as many updates as gravity has had since i bought it.
If only the symbian ecosystem had 10 more developers half as good as that german dude... well, using a symbian device would be a much slicker experience
Fascinating and helpful comparison. Some minor notes about Dabr:
1) multi-user support is vaguely handled by the fact you can log into dabr.co.uk, m.dabr.co.uk and www.dabr.co.uk with different logins.
2) if you switch in settings to "text" or "work safe" mode then images disappear. Helpful for smaller screens and people saving bandwidth.
Thanks for including Dabr 😊
Thanks for the kind comments, any and all (constructive) views are welcome 😊
Gravity is fantastic - it's actually one of the reasons I decided to use Twitter... rarely is there an app so easy to use it actually encourages you to use the platform!!
How do you make out that Gravity costs 5.98gbp?
On the Ovi Store it's 8gbp, and depending on which reseller you use from Gravity's own website the app costs 8.27gbp or 6.15gbp?
What's going on? I don't mind paying for apps, but I don't like paying over the odds, either...
Gravity did cost �5 something... but its now gone up to �8. currency fluctuations, added functionality... take your pick.
