mrh wrote:Hi,On Friday I updated my original t-mobile N97 to version 20 - in preparation for a family weekend sightseeing.
All went ok, didn't have any problems....
..... until I tried to charge the phone.
I'd used the phone all day, updating email settings and some ssh activity.
The charge indicator light comes on, and the phone bleeps.... but after leaving it all night the phone wouldn't turn on.
I've tried numberous chargers and cables - but none of them work.
Luckily I have a spare battery, but that will only last so long before it also us flat!
Any ideas?
http://www.fixya.com/support/t3237873-n97_not_come_am_charging_phone suggest the phone is corrupt? Hope not.
Many thanks
Matthew
This, in part, sounds exactly like a problem I've had for some time since going to v20.
When I plug the phone into the charger at night, it SHOULD go into charging mode which sees the handset screen light up, the little light by the USB port come on and then the screen turning off.
However, I find that about 45-50% of the time it doesn't do this. The screen comes on but there is no charging lamp and the screen stays on with the NOKIA logo in it's usual place. No charging is taking place and I'm sure if left in this state, the NOKIA logo would eventually burn onto the screen. To remedy this, I unplug the charger and plug it back in again after the screen has turned off. This invariably sorts it and the phone goes into it's proper charge mode.
The second part of the problem comes when I turn the handset on. At a similar level of frequency to the charging issue, the phone will either turn on normally or the screen will illuminate and then just sit there. The only way to get out of this is to remove the battery and re-insert it and start again.
On one occasion, the phone would neither charge or turn on and it was only the Vulcan death grip reset manoeuvre that allowed me to get the phone back on. Naturally, I lost a lot of data doing that.
I'm pretty sure it has only started doing this since the v20 upgrade so I'm hoping v21, which I installed yesterday, will sort it.
I'll keep you posted 😊
