RM553 upgrade?
3 replies · 2,992 views · Started 08 February 2010
Does anyone know a way to estimate when a firmware upgrade will be available for RM553 either OTA, OVI, or NSU?
Jeff
jmurch wrote:Does anyone know a way to estimate when a firmware upgrade will be available for RM553 either OTA, OVI, or NSU?
Jeff
HI Jeff,
I would guess that NSU will be your best bet for updating the phone's FW, other updates ( eg Nokia Maps ) can be done OTA.
Where in the world are you? Most handsets I've heard about are RM505 with varying product codes - have you checked with any local Nokia Care Centre's , they might be able to advise, and if it's an unbranded sim free handset, they will be able to update it for you.
Otherwise, might be worth asking the question on Nokia's Discussion Boards.
Good Luck.
I'm is the US and I bought this unlocked from Dell. I checked again and the code is correct.
I didn't mention this is a mini as I thought the model would ID it. Sorry about that.
Regards, Jeff
