i've downloaded the software upgrade for my N95 8GB but when i try to install it keeps saying that minimum memory requirement is 256 which im not sure if my laptop is. Is there a way to do it through the actual phone itself?
Many thanks in advance
There's no way to update firmware without connecting to a PC/Laptop mate.
There is other software to flash firmware (Nemesis/Phoenix) but I don't know their sys requirements off the top of my head.
Do u know how to check system requirents of a laptop?
bang bang boom wrote:Do u know how to check system requirents of a laptop?
In Windows XP
Start>Settings>Control Panel>System
The General tab tells you what the crack is
thanks for that.. 248 RAM it says.. hmm..
do u know if i can upgrade the NOKIA 5800 software direct on the fone?
On 5800 there allegedly is (this from Nokia UK website):
Key *#0000# into your phone's home screen.
Select Options > Check for updates.
Follow the on-screen prompts until your update is complete!
but it must need a wifi access point and god knows what'll happen if the connection drops
Ok thanks. Cant wait for it come tomorow
